» technoforum.de   » Produktions- & DJ-Technik, Hard- & Software   » [plugin] arturia - minimoog for FREE - 21.juni 2012
Autor Thema: [plugin] arturia - minimoog for FREE - 21.juni 2012
On June 21 only, musicians everywhere can download Minimoog-V Original from the Arturia website — for free! Minimoog-V Original includes all the sounds (more than 1,000 presets created by talented artists and renowned sound designers) and features (32-voice polyphony, plus much more besides) from the latest Minimoog- V update (Version 2.5), but without the additional functionality accessible behind the ‘hinged’ front panel — just like the original Minimoog.
Minimoog by name. Minimoog by nature. It’s been several successful years since Arturia announced the release of its much-admired Minimoog-V soft synth — meticulously modelling the distinctive tones and analogue nuances of the legendary Seventies-vintage Minimoog Model D monosynth — in an agreement with Moog Music initiated by Bob Moog himself. Moog changed the musical world with the Minimoog and Arturia helped change the music software world with the Minimoog-V, so what better way to toast the passing of that productive partnership and end the arrangement between the two companies on a high note than with a generous giveaway on World Music Day?
Don’t miss out: go get Minimoog-V Original for free on June 21! Save the ‘download date’ in your calendar…
[hand] http://www.arturia.com/evolution/en/products/minimoogv/minimoogv-original.html
/bump, in knapp 4 Stunden verfügbar, u.U. könnte es sein, dass der Server zusammenklappt, also schnell sein? Oder man braucht'n syncrosoft-Dongle? Andernfalls definitiv 'ne ganz feine Sache, Moog für lau! Bin gespannt...
hendrik-d
AEstronaut
Usernummer # 8293
[flamingdevil]
bin auch gespannt & hoffe man braucht keinen dongle.. aber notfalls hol ich mir dann ma einen, fragt sich nur woher ich den freien usb slot nehmen soll.. an der tastatur is noch was frei *g*
Der Server unter www.arturia.com braucht zu lange, um eine Antwort zu senden.
[Frown]
Okay, sowas von überlastet, hier wären die Links, derzeit aber ist ein d/l kaum möglich, weil nun natürlich gerade eben der 'run' auf das Plugin läuft, notfalls müsste man sich das Ding also doch per Torrent ziehen ;-/ nach Registrierung erhält man dann einen persönlichen key:
To download the Minimoog V Original, go to:
- Windows version :
http://www.arturia3.com/downloads/minimoogv_original/minimoogv_original.exe
http://www.arturia.com/downloads/minimoogv_original/minimoogv_original.exe
Using Torrent : http://www.arturia3.com/downloads/minimoogv_original/minimoogv_original.exe.torrent
- Mac OSX version :
http://www.arturia3.com/downloads/minimoogv_original/minimoogv_original.dmg
http://www.arturia.com/downloads/minimoogv_original/minimoogv_original.dmg
Using Torrent : http://www.arturia3.com/downloads/minimoogv_original/minimoogv_original.dmg.torrent
The first time you will launch the Minimoog V Original you will be asked to enter an activation code.
Your personal activation code is: xxxxxxx
silicon
AErodynamic
Usernummer # 503
Also den MAC OSX Download habe ich jetzt. Falls jemand den braucht Bescheid geben ...
Cheers,
hendrik-d
AEstronaut
Usernummer # 8293
hmpf.. war ja klar.. bekomm die ganze zeit n ladefehler.
geht allerdings auch über fb. wenn man auf den link hier
Arturia's Fan Page
klickt, kann man sich eintragen & bekommt dann innerhalb der nächsten 48 std. nen link & registry key per email. Der Haken ist halt, dass man so n doofes fb app nutzen muss.
aber besser als nix [Smile] .. die seite ist zumindest nicht überlastet^^
psyCodEd
Usernummer # 4608
..die app fragt ja auch nur die email ab. kann man ja danach direkt wieder de-aktivieren.
Ursprünglich geschrieben von: hendrik-d:
Arturia's Fan Page
die mail mit dem aktivierungscode hab ich schon längst. bringt aber nichts, wenn man sich die exe-datei wegen server-überlastung nicht runterladen kann...
psyCodEd
Usernummer # 4608
reicht es denn im prinzip nich sich heute den key zu besorgen und nächste woche die demo zu laden wenn die server wieder bishen luft haben?? oder ist das heute eine spezielle version? hm.
Jo, ggfs. findet sich hier immer jemand, der die osX- oder Windows-Version zu Verfügung stellen kann, die .dmg für osX beispielsweise hab' ich zwischenzeitlich lokal archiviert. Schau' also, dass du zumindest den Key noch bekommst.
psyCodEd
Usernummer # 4608
- Windows version :
bei mir funktioniert im moment der link hier ganz gut. jetzt noch auf den key warten ^^
Quinto
Usernummer # 1412
jepp. s. oben den text von chris. zitat: "but without the additional functionality accessible behind the ‘hinged’ front panel — just like the original Minimoog."
ich hab den damals schon gekauft und möchte die modulationsmöglichkeiten, die sich hinter dem aufklapbaren panel verstecken nicht missen. da lässt sich allerlei unsinn mit anstellen, der jener free-version fehlt.
hendrik-d
AEstronaut
Usernummer # 8293
das tolle an so freeware dingern ist halt unter anderem auch, dass man für gemeinsame projekte - z.b. geteilt über dropbox - eben die gleichen vsts nutzen & laden kann & dann auch die automation etc. vom kollegen sehen kann
jau, zugleich aber auch ist der sound wirklich superbe und roh und wenn ich sagen würde, er wäre unglaublich nah am original, dann ist das bei den arturia-produkten sicherlich eine untertreibung. es gibt zwei, drei andere moog-freeware-emulationen, vornehnlich aber für windows oder eben doch mit 'nem eigenen sound: ich hatte früher einige arturia-produkte für die r'line getestet, leider sind die lizenzen ausgelaufen und ich kann sie auf meinem 'aktuellen' apfel nicht mehr nutzen: die presets haben mich eigentlich nie wirklich vom sockel gehauen, aber mit ein paar handgriffen kann man eben flux 'n dicken, schönen, voluminösen sound aus den dingern ziehen und daher find' ich das heutige 'give away' trotz der fehlenden zusatzfunktionen erstklassig, wird am we dann endlich installiert.
Moodyzwen
Chicago-Rocker
Usernummer # 4967
Hmm - verpasst weil ich im Urlaub war.
Jemand eine Idee ob und wie ich noch an eine Lizenz komme?
hendrik-d
AEstronaut
Usernummer # 8293
ich würd einfach mal ne freundliche email schreiben.
hab bis jetz bei musiksoftwarefirmen das erfreuliche gefühl gehabt, dass sie sich freuen, wenn ich ne frage habe. Ein Versuch ist es sicher wert.. also nicht über Facebook oder so, sondern direkt übern email support.. einfach anschreiben & auf ne Antwort warten. Ne Antwort schreiben sie dir dann in jedem Fall.. ich drück ma die Daumen
Da ohne Facebook Account nen Kumpel gebeten, hat aber nicht geklappt. Eine Mail an Arturia blieb bis jetzt ohne Antwort. [furchtbartraurig]
Ursprünglich geschrieben von: mantis:
Schade ;-/
Da ich von 'nem challenge-response-key ausgehe, dürften die Eigentümer des Keys den wohl nicht einfach im Netz verteilt haben. Du könntest natürlich auch auf'n Fehler beim Registrieren der Daten im Formular hinweisen, war ja zeitweise wirklich mehr als überlastet und dich an die für diese Aktion dediziert hinterlegte Kontaktadresse wenden?
In case you are experiencing delay in receiving your email, please contact minimoogvoriginal@arturia.com
